create a “Web scenario failed” trigger
  • taxiarxos
    • Sep 2014
    I have checked this link https://www.zabbix.com/documentation...nitoring/itemsinto the documentation and now I am trying to configure this trigger for my company's web site.
    I have create the web scenario and the step for the site and now my problem is that zabbix sees all the time down the site. The expression I have put is
    {ip or hostname of the web server:web.test.fail[scenario].last(0)}#0
    I don't know if I have something wrong or it doesn't work due some delays, because I get traps via another zabbix proxy and the wan link is slow. I that case which is the number should I increase to make more delay on this check?
    Another strange thing is that I don't see these items after I created the web scenario.
    "As soon as a scenario is created, Zabbix automatically adds the following items for monitoring, linking them to the selected application."
    Also I am checking the item web.test.fail[Scenario] I created and pointed to zabbix agent and got status "not supported"
    Thanks in advance,
    George
